Downhaul and Jib Sheet Questions
Post All Rigging Topics Here
T.Bird
Postby T.Bird » Wed Oct 07, 2015 4:50 pm
When I introduced myself as a new C22 owner I said that I was happily finding the answer to most of my questions to be readily available online. But alas... I have a few questions to lay before you guys.
Downhaul. The boat didn't come with one, but from what I can gather from the picture in the owners manual on the documents page, it doesn't look like it should take much more the a simple line between the ring under the gooseneck to the ring at the base of the mast. Am I missing anything here?
Also... It seems like the jib sheets need to be run through some sort of movable blocks on the toerail in order to achieve proper sail trim, no? The boat only came with fixed blocks on the cockpit combing, but these seem too far aft. Any (hopefully cheep!) recommendations for blocks that could remedy this?
C22
Be humble for you are made of earth.
Be noble for you are made of stars.
monty
Postby monty » Thu Oct 08, 2015 7:39 am
my 26 has no genoa tracks, I use snatch blocks attached to the toerail. works fine
Messing About
T.Bird
Postby T.Bird » Tue Oct 13, 2015 4:13 am
Any advice for a novice sailor on where to place said blocks (fore and aft) in relation to different size headsails?
C22
Capt. Bondo
C Shirt
C Shirt
Postby Capt. Bondo » Wed Oct 14, 2015 12:06 pm
It's going to depend on the size of your head sail, the larger the head sail the farther back you need to attach the blocks.
I know that when flying my working jib (90%) the blocks are mounted two holes in front of the rear lifeline stanchion. You may need to play around with the location until you get the correct sail shape, then mark them with tape or a Sharpe.
Postby EmergencyExit » Wed Oct 14, 2015 4:50 pm
T.Bird wrote:Any advice for a novice sailor on where to place said blocks (fore and aft) in relation to different size headsails?
Capt Bondo has good advice on which way to move and mark the blocks. You can also get a ballpark location by sighting along the jib sheet towards the sail. That line should usually bisect the jib clew.
T.Bird
Postby T.Bird » Thu Oct 15, 2015 11:29 am
EmergencyExit wrote:...That line should usually bisect the jib clew.
Thanks guys! We're getting it out on the water for the second time this weekend. We'll start with this as a reference point.
C22
Return to “Rigging Tips”
