electric
blu by you
electric
Postby blu by you » Sat Nov 05, 2011 3:04 pm
i found the wires going to my mast light to be in poor condition , has anyone run new wire through the mast and how hard was it. thanks
Bhacurly
C Shirt
C Shirt
Postby Bhacurly » Sat Nov 05, 2011 3:23 pm
It's a good Winter projecr.
I know Alan did it recently an there is a good post on it here somewhere.... Here it is.. good info:
http://www.chryslersailors.com/discussi ... sc&start=0
lecker68
Postby lecker68 » Sat Nov 05, 2011 4:19 pm
Make your Harness outside the mast and then use a wire snake longer than your mast you may be able to pull a chaser line in with your old wiring and pull the new wiring in with it.
blu by you
Postby blu by you » Sat Nov 05, 2011 7:10 pm
again the site comes through many thanks
johnjax292
C Shirt
C Shirt
Postby johnjax292 » Mon Nov 07, 2011 8:50 am
I have also seen a trick using a strip of cloth tied to your wire harness and a vacum at one end of the mast. The cloth is pulled through by the vacum...it worked better than expected.
John
s/v Gatta Nostra
1977 C22
thepartydog
Postby thepartydog » Mon Nov 07, 2011 12:15 pm
When I'm running network cables thru conduit, I use a walmart bag, pull string and vacuum. Works great.
Darin
"Ya Never Know"
1980 C26
Return to “Electrical”
