Maximum Outboard for Chrysler 22?
Post All Outboard Topics Here
Zac Penn
Postby Zac Penn » Wed Aug 21, 2013 3:07 pm
I know in the manual it says maximum of 15 hp, but I am wondering why that is? Does it have to do with the motor weight, or the stress on the transom from more torque?
I am trying to find a good motor for my boat and stay under $500. There are a couple options, but I found a 25 hp for $400 and don't want to even think about it if the boat will be harmed.
If it has to do with the toque then I can keep it at half throttle (maybe even fabricate a governor to keep from over powering.
If it will just be too heavy then that is that ;)
I have what I believe is the factory motor mount...
Capt. Bondo
C Shirt
C Shirt
Postby Capt. Bondo » Thu Aug 22, 2013 10:48 am
You realy don't need anything over 10hp. To much motor weight makes the stern lower in the water, and as the C22 speeds up under power the stern will squat even lower in the water. Under power, at hull speed the back of the engine cowling on my Sailer 280 is in the water :shock:
Also the stock motor mount could not handle a 25hp for to long.
Postby CaptainScott » Thu Aug 22, 2013 11:19 am
Yeah, I agree, 25 is to much everything.
weight, torque, physical size, etc.
I'd rather hold out for a 10 or less. I run a 4 stroke 9.8 hp motor and THAT is to much for my OB bracket. I'm looking to replace it with a nice larger newer 4 stroke braket that will allow me to tilt the engine properly while sailing.
Zac Penn
Postby Zac Penn » Thu Aug 22, 2013 11:36 am
Okay thanks for the replies. I might have a lead on a 5.5 hp so fingers crossed.
I have also been toying with the idea of making my own motor with an old lawnmower engine and an outboard lower unit/leg whatever they are called. There are quite a few of those on YouTube and I am sure i could fabricate some kind of muffler for it so it wouldn't be so freaking loud. This will only be if nothing in my price range shows up and I really get antsy to get on the water.
tdupras
Postby tdupras » Thu Jun 26, 2014 12:29 pm
Sorry for replying on such an old post.
In my experience I went from a 7.5 hp to a 5.5 hp (both 2 cycle). I only lost about 0.5 knots at maximum throttle but I went through about 1/3 less fuel. The 5.5 is excellent for getting from point A to point B but I found it lacking when it came to getting the boat over anything bigger than 6' swells. Later on down the road, tonight look for something closer to 9 hp.
Torrey Dupras
C22 Venetian Night
Return to “Outboards”
