Outboard Lock
Post All Outboard Topics Here
norm6804
Outboard Lock
Postby norm6804 » Tue Jan 17, 2017 12:40 pm
Does anyone know of how to lock the outboard in the straight position?
Mine likes to wander while I'm sitting in the cockpit trying to steer with the rudder.
Any info would be great.
Capt. Bondo
C Shirt
C Shirt
Postby Capt. Bondo » Fri Jan 20, 2017 12:07 pm
On many older outboards there is a adjustment bolt/screw on the upper or lower steering bracket that you could tighten up.
On my Chrysler outboard there is a simple bracket the runs from the transom clamp to the tiller mount that locks everything straight.
NOTE this arrangement will NOT allow you to use your motor to steer in very tight maneuvers.
Reality
Postby Reality » Fri Jan 20, 2017 6:21 pm
a couple bungee cords from each side of the transom to a small "lever arm" attached to front of motor (or to a velcro strap around the tiller arm)
Return to “Outboards”
