Replacing V-Berth Plywood
bearley
Post by bearley »
Can someone tell me how the fixed pieces of plywood in the C-26 forward berth are attached to the sides of the hull? I want to replace mine, but I can't see how it attaches.
'glassed in with about 4" wide tape. When you cut the ply pieces take into account the angle of the hull and the pieces will wedge in place under their own weight, then you can glass them in..there's bit of a trick to it to get them to wind up at the same level as the 'ice chest' bulkhead, so mark the hull before you rip out the old, then overcut and then sneak up on it...
been there, done that, twice on two different boats now.. 8)
Chrysler20%26
Post by Chrysler20%26 »
More good info, from the man on C-26 Thank You EE
Well, its like that fellow Red Green up at the Possum Lodge says...'if the women don't find you handsome, they should at least find you handy'... :wink:
bearley
Post by bearley »
Thanks, EE.
I can understand what you mean by "sneak up on it". I may try attaching a few blocks to the hull sides with epoxy, and laying the plywood on that. Would you recommend a thicker plywood than original?
I used thicker than original on EE, and original on the project boat..original on the project boat sagged a bit until I braced it.
I'd go a bit thicker, more forgiving..
Also both EE and the project had a 3 piece system in the VBerth, 2 small side triangles, a smaller triangle in the middle and farther forward with bracing under the joints..I used one solid piece on EE, but followed the pattern on the project. One big one was easier to adjust to fit right..and felt more solid..
hp18carr
Post by hp18carr »
You guys replacing your V berth plywood... a few photos please. I don't foresee a full V berth replacment in my future. However I will need to reinforce the sides of the V berth where a P.O. cut out an access hatch.
Chrysler C26' 1980
ask and it is done !!
A few EE pics here
http://pwp.att.net/p/s/community.dll?ep ... 280880&ck=
And some Fairwinds pics here..
before
during
and almost done
EmergencyExit wrote:..I used one solid piece on EE, but followed the pattern on the project. One big one was easier to adjust to fit right..and felt more solid..
No I didn't, lol...its all running together...I used one piece of the thinner on the project..looking at the pics reminded me..memory is slipping..
mcrandall
Post by mcrandall »
Beauty!
mcrandall wrote:Beauty!
Thank you ! Hopefully that will be her next owner's thoughts first time he sees her !! Would love to keep her but two C26's (and a Cal21 and a Coronado C15) would be a bit much...
Hoping to get down to just EE and the Cal21..if not just EE.
EmergencyExit wrote: Hoping to get down to just EE and the Cal21..if not just EE.
No your not! LOL! You love it and you know it!!!! :lol:
Who ? Me ? :roll:
hp18carr
Post by hp18carr »
E.E.
I'm sure there are a number of us who envy your boat problem. Thanks for the photos, as you can see in this work in progress photo that the access hatch cut into my V-berth is a considerable size. The two smaller triangle looking sections to Port and Starboard are what need extra bracing. I could be wroung but my old V-berth looks like a one pice cut.
Chrysler 26' 1980
hp18carr wrote:E.E.
8)
..but it gets to a point where you don't have time to use any of them for figuring out what to fix next on another of them !!!
One man, one woman, one boat..words for the wise to heed, lol...
thepartydog
Post by thepartydog »
Terrance,
You've got the same fore deck design as i do and my v berth decking is the same design also, with the large access hatch.
D
Darin
"Ya Never Know"
1980 C26
bearley
Post by bearley »
Terrence,
What are you using to smooth the side walls? (I hope he doesn't say "tons of elbow grease!) :wink:
If you look closely at the before pics on Fairwinds, you'll see the same large cutout for the hatch. Really weakens the vberth in my opinion.
Bearley I can tell you how I smoothed the sides..I didn't. Between the pretty white vinyl and the hull is a thin panel of solid pink foam board..
hp18carr
Post by hp18carr »
Bearley
The tons of elbow grease is not far off... :wink: . The photo is not close enough for you to see that even after a couple of coats of primer the walls are far from smooth. I'll make due with just working toward a new paint job for now, here is an old as found photo to show that progress is being made.
Chrysler C26' 1980
