Deck Paint Recommendation
OldUgly
Post by OldUgly »
Eventually I'm going to paint the worn out top side of the C26. Is there a paint type that you guys can recommend or suggest to stay away from? Is a primer neccessaary? How many coats do you suggest? As you can tell, I've never painted a boat deck before. About how much paint will it take to cover the top of a C26? Seems like a gallon went a long way on the bottom when we painted it last summer...What about prep work? Is sanding necessary? Lot of questions I know, but just would like some opinion from you folks that have done this work before.
Thnx.
Patrick
Post by Patrick »
Hi Jim .
For my C22 I have used this , Interlux , very good result but first try just to '' revive '' the gelcoat , I try to find what I have used and tell you :
http://www.yachtpaint.com/usa/default.asp
Patrick
Post by Patrick »
Hi Jim ,
The stuff is call MAG , it's the one in the right up corner , I Am sorry ,it's in frech but try to find this and a good buffer , good result ;
http://www.entrepotmarine.com/Catalogs/ ... &PathRef=1
OldUgly
MAG
Post by OldUgly »
Thanks. I'll look for it locally.
Patrick
Post by Patrick »
Hi Jim
If you can't find it localy , this store can send it to you .
http://www.blyachting.com/En/Default.asp?
