Replacing V-Berth Plywood
Posted: Sat Mar 24, 2012 2:06 pm
by bearley
Hello,
Can someone tell me how the fixed pieces of plywood in the C-26 forward berth are attached to the sides of the hull? I want to replace mine, but I can't see how it attaches.
Posted: Mon Apr 08, 2013 4:29 am
by Whabadoo
I just removed the cushions from my v-birth on my "new" C26 and found that the forward plywood was completely Rotten.
Looks like the old plywood was glassed in, Thinking That I could simply cut out the rot and lay 1/2 in plywood on top the the remain fiberglass edge, add some support and be done with it.
Posted: Thu Apr 11, 2013 4:06 pm
Glassed in with tape - also they are cut at a slight angle so they wedge into place..
Posted: Fri Apr 12, 2013 5:48 am
by Whabadoo
edfarra
Posted: Fri Apr 12, 2013 5:53 am
by Whabadoo
Posted: Fri Apr 12, 2013 6:57 am
Been there done that...twice. Go back with a bit thicker ply than original too. Also (from the link I have posted before)check and maybe replace the bulkhead between vberth and anchor locker. Its a pain but that bit of sealant at the bottom of yours means something !
