What a day! I installed two inspection ports, and I removed, cleaned and resealed the tramsom hardware. I was surprise that chrysler had a good 1/4 inch of wood in there, so I didn't needed to add backing blocks. With fresh 4200 I pray it will not leak now
Next projects are: finding a way to install the battery in the port side (my outboard has electric start to it has to go in the bilge under the cockpit)
And project 2, my boat came with no winches. There's no evidence that my boat ever had winches. What I've got, two harken high load clam cleats, I was thinking in installing the cleat foward of the block mounted in the coaming, is that a good idea?
Gus
Trying to get the boat ready...
Pictures
here's the link:
http://www.flickr.com/photos/gus_chrysler22/
(couldn't figure out how to post pictures in my message)
I found another person with some Chrysler 22 pictures, here's the link:
http://www.flickr.com/photos/7804442@N04/
I uploaded some more pictures (fishfinder mount and cam-matic cleat mount)
Thanks Patrick! I love the boat, but... man, I'm fixing some rotten core under the lifelines stanchions... what a PITA!! Two days and I just did 2 in the starboard side!!! grrrr.... I'll try to finish the last one tonite.
Basically, what I found after cutting the liner... I found a piece of plywood in good condition, and some balsa core, totally rotten. Looks like when they installed the stanchions, they miss the backing plywood!! The stanchion sits in the balsa core, and since it was rotten, the deck would bulge down... well, all that is gone now, I removed everything, epoxied and glassed a new piece of wood. Two done, 4 to go.
Gus
Gus
