Mastlight
Mastlight
need a new light. What is best place to get a mastlight?
Check eBay, I found a mast light with a built in deck light that shines down to light the deck. I wired mine with two wire, an anchor light on top, and a ground wire, so I now have 4 wires running through the mast.
With each light on a seperate circuit, and since they should be on one at a time, current draw should be less than 2 amps per circuit.
1979 C22 S/V Client Meeting
