Jib/Genoa tack...
astrorad
Jib/Genoa tack...
Post by astrorad »
I suppose I should have posted this in rigging tips...but this gets more traffic...What does everyone use to attach their jib/genoa tack to the stemhead fitting? Looking for advice here...no furler.
I use a small block on the fitting.
Then I tie a line to the tack, run it down through the block and then back to the for deck cleat. Simple, easy and adjustable.
If I really want to, I can use a longer line and run it aft allowing me to raise and lower the tack form the cockpit.
I'm lazy and choose not to for now! LOL!
astrorad
Post by astrorad »
Thanks Scott...sounds like a good idea...funny thing though, 74 views and only one reply...go figure!!!
mcrandall
Post by mcrandall »
Momma always said, "If you don't have something nice to say..."
I chose to slightly modify that with "If you don't have something smart to say..." :wink:
Andiron120
Tack
Post by Andiron120 »
I have always used a shackle for this, but believe I will use Capt. Scott's method from now on. Sounds like a better idea to me.
astrorad wrote:Thanks Scott...sounds like a good idea...funny thing though, 74 views and only one reply...go figure!!!
Everyone is tired from all they sailing they've been doing! :D
tgentry
Post by tgentry »
I use one of these at the tack and another at the head. I also have a short line that I keep on the tack of each sail because I like them better about 9" off the deck.
http://www.marinepartdepot.com/newststtashw1.html
