Hull Flex Near Bow
Hull Flex Near Bow
The hull of my C22 has a bit of flex on both sides of the boat near the bow. Maybe only a foot or so of flexy area. It feels to be relatively equal on each side. Is this by design or is this a sign of delamination? The rest of the hull is solid.
That would be my guess as well, but I was hoping it just may be a common thing. I pushed around on the bows of some of the other boats around the club and several of them also had some flex in this area. I'll admit I'd rather it be rock solid though.
Is there a preferred "fix" for this, other than cutting out and replacing glass?
Has anyone else experience delamination on their C22? The decks are very solid, as is the rest of the hull. It is just an area about a foot or two off of the bow. The bow itself does not have any flex in it at all. How concerning is it? Obviously a completely solid boat is better, but how much does it reduce the safety of sailing the vessel?
- Capt. Bondo
- Capt. Bondo
I had to check since Happy Place is in the yard getting it's mast re-wired (pictures and story to come).
I would not worry about it if there is no cracks in the gel coat. It's well above the waterline, and not in an area that takes a load often.
I also have flex where you described. The inner liner just does not contact the hull in that area, but is very close behind, on the starboard side I feel it hit the inner liner when I pushed on it
I have done extensive work on my boat, 1976 C22, and have never noticed any flex in the hull where you have described. I have sanded the entire hull and I would think that I would have noticed it. As others have said...it probably is not a worry as I do think that this is a thinner section of the hull.
Thanks everyone. My situation sounds similar to Capt. Bondo's. Upon further inspection the starboard side does have more flex and I can also feel/hear it outer lining contact the inner.
So, it's sounds like possible delam but perhaps it's nothing to be concerned of for now. I'll certainly keep an eye on it. I know some boats are prone to it in some areas and perhaps this is one of those cases. I agree that it is not in a high stress area.
I still think she is a solid boat. She's already brought me more joy than I had dreamed of and I know there is much more in store!
