boat set with water in it for a while
Special area for the smaller Chryslers - Musketeer, Buccaneer, Mutineer, Man O' War, Pirateer, Daggers, etc.
gerald
Postby gerald » Sat May 25, 2019 8:07 pm
Just bought a 16ft LoneStar it had set for sometime with a bunch of water inside the boat so the floor completely rotted out, got all of the floor taken out. There is a type of foam under it that is water logged, I raised it up as high as I could to try to get the foam to dry out, the top inch dried but it was still heavy. I put it in the water and it leaked really bad so I got a sump pump used a drill battery to operate the pump. I did get to sail it, but stayed busy trying to keep the water out. Has anyone every taken all the foam out of one? Was thinking about doing that getting rid of double dagger boards... building a center console. And putting a type of styrofoam that will not water log back in. Advice from anyone, the outside hull looks good ...... the sails are it good shape.
couch sailor
Re: boat set with water in it for a while
Postby brigadoon » Wed Aug 28, 2019 10:51 am
Hi Gerald,
I’m glad to hear you got to sail your boat. I’ve been a boat mechanic at a marina in Co for a number of years where the docks were set on floats ( commercially produced for the purpose ) . Once foam becomes water logged it generally never dries out. I had blocks of water logged foam that were set out for years that would never float again. Remove the foam entirely and if you feel it is necessary to replace it go find a source for replacement . Home Depot May do with their sheet foam in sheets. For more help post a question on the general discussion board , it will get much better exposure . I hope this helps if you have not corrected the the problem yet. Also removing the foam will make it easier to find and repair the leaks.
draftingrus
Postby draftingrus » Tue Oct 27, 2020 7:47 am
I have a lonestar 16 but it has no foam in the floor - the hull is just a single thick layer of glass with the roving pattern visible on the inside of the hull
draftingrus
Postby draftingrus » Sun Nov 01, 2020 10:10 am
I might have misspoke - I tried flipping that boat yesterday with the best of Volunteer a nearby tree and harbor freight deer dressing pulley kit and Boy ... that did not go well - your statement of the boat being double hulled and foam cored might well be truth -since boat and trailer resisted with force that exceeded expectations.... my opinion was based on an earlier statement that the boats were prone to oilcan due to it's flimsy hull in the midships ...
Return to “DaySailors”
