As so many before me, I need to consider buying a new motor for my 22FK, and wonder about the length of the shaft.
I did dig in the old posts, but could not find a satisfying answer.
Apparently most use a 25" shaft, but everything also depends on the motor mount.
So my question is: where on the hull do I measure for the right shaft length?
Do I use the lowest point on the stern or do I use the lowest point of the hull (minus the keel)?
Or something else?
Thanks for once again dealing with OB shafts!
OB Shaft length (again)
Mr.H
1976 Chrysler 22 FK
1976 Chrysler 22 FK
