![Question :?:](./images/smilies/icon_question.gif)
Actual Weight
Actual Weight
- Windwalker
Displacement
Displacement is the weight of the water the boat displaces when it is floating. This will be the weight of the boat. So, displacement is the weight of the boat….stripped. It does not include any equipment, stores, sails, etc., all that is extra. Not sure on a Chrysler 22, but my 26 has a displacement weight of 5000 lbs. I calculated 5750 lbs loaded to sail, not counting the trailer weight. One of these days I will have to put it on some scales.
There is also a figure for maximum displacement - defined as the weight of the amount of water displaced by the boat at its maximum immersion level in calm water without water coming aboard.
I agree with Windwalker - surely the Chrysler folks did not use that maximum figure, so the boat likely weighs its displacement.
