C 22 Tiller handle wanted, Or Prints to build one. I just got a 22 and there is no tiller. Also looking for the outboard bracket.
[/b]
Wanted C 22 Tiller Handle
HI
I just got a great deal on a new tiller on e-bay.
I have worked on my old one for 3 years to keep it good and finally said no more. The original length is around 40-43"
If you look at www.idasailor.com they have new ones their.
I have also heard of some using a wooden axe handle for temporary.
Good luck.
Good luck.
Jeffrey
Fore Sail
1976 C-22
Fore Sail
1976 C-22
Jeff, Thank You, We just got this boat which appears that you have the same one, 76 C-22. It is all stripped down & dismantled., I'm in the process of getting it ready to paint. Atfer which I will attempt to re-assemble it. I will post some pictures as I move forward. The weather has'nt been the best for working outside up until now.
I do have a question about the two stabilizers on the mast? They are loose but secure, is this something that should be rigid with no play at all?
Thanks, Tim
Thanks, Tim
