Fixed Keel Question
Posted: Sat Apr 18, 2009 4:03 am
I'm in the prosess of re doing the bottom of my 22 & I found that most of the seal is cracked or missing where the keel meets the hull. I plan on cleaning this old caulking or whatever it is and replacing it.
can someone tell me is there a specific sealant or caulking that should be used? I dont want any leaks when i launch this summer.
as you can tell from the picture theres quit a bit of work to be done, mostly wlbow grease. the gentleman that I got this boat from has everything bagged & tagged. which I'M thankful for. It will speed up the re assembly process.
