Rebuilding interior
Posted: Wed Jun 24, 2009 7:07 pm
I am at the point now that I will start rebuilding my chainplates. I wanted to throw an idea off some veteran sailors and see what you guys think of my idea. Hope this makes sense.
First off I already cut back some of my seats to gain access to the hull.
then I added corner reinforcements which were attached with 3m 5200 and will soon be glassed over.
Now what I want to do (looking for suggestion on this idea) is fiberglass bolts to the hull. 3 or 4 bolts for each chainplate. these bolts will later be used to bolt a brace to and this brace will connect directly to the shroud fasteners. I have fabricated a 4x10 inch piece of 1 inch fir that the bolts are fastened to. This will then all be glassed to the hull, about 15 inches below the deck.
So there will be 3 bolts per shroud that will allow a bracket of some sort to bolt to the hull.
I decided to go this route because I didn't know if I wanted a steal bracket or a fiberglass reinforced wood bracket. With these bolts I will be able to try different types of brackets to transfer the shroud tension to the hull.
I was also wondering if anyone could tell what would be best for fiberglass. Matting or cloth?
Oh ya, here is a pic of the concrete I poured over the lead shot. Before I poured the concrete I put plastic down so it wouldn't soak in with the lead shot. Now it is super easy to remove the concrete. There are 3 pieces about 30 lbs each.
Here also is an update on my cockpit floor replacement. I would like to say thanks to windward for the wonderful idea of hydraulic jacks for keeping the wood in place while the epoxy sets.
Now the next question to many is for the mast post in the cabin. I have found that the mast post pushes really hard on the floor which has cracked and weakened it.
I was thinking of using a treated 4x4 and adding a steel brace at the base of the post to distribute the weight. Any ideas? I don't want to rip anymore of this boat apart since it's costing me 4 hours of repair to every hour of dismantle.
If anyone wants to see all the pics you are more than welcome to go to my site.
http://picasaweb.google.com/adam.mayotte/Renovations#
Thanks for all your input and any idea is appreciated.
Adam
Adam
