Would you repair your main sail of a c26 from 1977.......?
I blew my main sail out on June 24th in a surprize puff. would you fix or replace? What would you do?
C26 1977, white hull blue rub stripe, main sole #437, Bough in the Seattle area.
If it were me, I'd start budgetting for a new sail and then promptly try to fix the blown sail myself. If the fix works and holds, I have budget for new but not spent, if the fix fails, then I have budget for new that will get spent!
It would make a perfect oppurtunity to practice your sewing skills!
I would follow Cap'n Scott's advice except that I would probably buy the new sail regardless. Then your old sail becomes a spare.
