Rudder post leak?
Posted: Wed Aug 19, 2009 9:36 am
Ok, I was doing some work on the Betsy Wetsy and thought I should dip her in the lake prior to hauling her 3 hours north this past weekend.
I backed her into the water next to the dock at the ramp so the water level was up past the keel pocket. I waited until early evening so I wouldn't be hogging the ramp.
I went inside with a flashlinght and climbed around and didn't see any leakage. So, after a few minutes I pulled her out to take her home and get her ready - cleaning out the dust and putting all the cushions, etc back in.
I get her home and look inside and find that there are a couple of inches of water inside of her....
So, I crawl around. I notice a little water in the compartment on the starboard side with the thru hull for the sink drain. However, the dust between the thru hull and the lower corner in the compartment is dry.
I then crawl under the cockpit and found that the dust between the rudder post and the battery is dry.
I had the rubber cap that covers the starboard side bracket off so I could check for leakage around the keep bracket and to also see if a repair I made to the front of the keel pocket was holding.
If a rudder post assembly leaks, can water get in between the outer hull and the hull liner and then after trailering come forward and wind up in the starboard compartment and then work forward and come out where the starboard keel bracket cover is suppose to be?
Mike
Mike
