Rudder restoration
Posted: Wed Sep 16, 2009 4:07 pm
So I'm finally gonna pull and change the lines on my C22 Rudder assembly.
What a mess this old thing has become. So many areas of damage over the years before I ever got her . So I decided to grind out all the chipped areas and remove this flaking fiberglass from pivot area. I have ground both
"cheek " areas down to remove cracked , flaking fiberglass and resin. It looks like someone built the areas up where pivot bolt goes through. It has really gotten bad which explains some of the difficulty in it's ease of function. So I have filled in all the chips and divots with repair resin and I guess I will rebuild the ground out fiberglass cheek areas and finish grind to as smooth as can be. Now, what should i use to restore a nice uniform color to the restored rudder. Do most of you guys go with white ??? Is it simply a marine grade paint i should use ? Anything I might want to know about pivot plane area before it's too late ??
Jeff
Jeff
