Overhaul... transom trouble
Posted: Wed Dec 16, 2009 7:26 pm
by hp18carr
It seems the po extended the cockpit locker and enclosed it with untreated painted plywood. You will not the fitting top left is the bilge exit point, all the bilge water directly into the transom... not good the way I see it. Hopefully all the rotten wood is centered close to the locker extension.
I ripped out all the old carpet in the cockpit locker, just more prep work for my growing list of summer 2010 projects
Chrysler 26 1980
Posted: Wed Dec 16, 2009 8:15 pm
by monty
That's a factory installation! Had to rip out all that mush on my boat too!
Posted: Wed Dec 16, 2009 9:36 pm
Posted: Thu Dec 17, 2009 6:21 pm
by al the pal
I was just wondering about that plywood just today. I was hoping to attach an AC breaker box to it since that will be close to where the shore power is going to come in (current plan)... but it does look suspect.
Thanks for posting this!
Posted: Fri Dec 18, 2009 5:17 am
by hp18carr
When I get around to working this little problem, I'll just fiberglass in some treated plywood, or if I have a little extra cash marine lumber. Also change the bilge exit point.
Chrysler 26 1980
Posted: Fri Dec 18, 2009 4:46 pm
by lecker68
My bilge pump comes out above sink drain behind bulkhead Just below toe rail. work done by orig. owner
Posted: Fri Dec 18, 2009 8:11 pm
by hp18carr
With the bilge exit point already in the transom, the simplest fix would be to purchase a few more feet of bilge hose and incorporate it into the closest screened drainage point next to the motor mount.
Chrysler 26 1980
Posted: Fri Dec 18, 2009 8:25 pm
by lecker68
Yes Terrence Get it outside the hull. A through hull would look good that is what I have.
