Overhaul... cracked tiller head
Posted: Sun Dec 20, 2009 8:08 pm
by hp18carr
Pandora's tiller head is cracked, sorry for the out of focus pic... cheap cam. It appears not to be too deep, but a broken tiller head in the middle of the lake is something I would like to avoid. Is there any type of fix on this type metal (aluminum or aluminum alloy) I'm not really sure which it is? Could just filling the crack with a type of epoxy or liquid nail do the trick, or should I just have a shop fabricate a new one?
Wilmingotn N.C.
Chrysler 26 1980
Pandora
Posted: Mon Dec 21, 2009 12:40 am
I'd take that to a shop and see if they could weld it. A guy I was in class with last quarter was a welder befroe getting laid off and he said he could weld stuff like this in a quick minute. I thought it was more complicated but he said no it was easy.
Now I've never welded aluminum but I've see the end product done by skilled hands. I would think it would be good as new. Maybe even file off the bead when there done for the nice clean look.
Posted: Mon Dec 21, 2009 1:26 am
by Chrysler20%26
I wont to thank for all the photos you have posted. An yes to haveing it wilded, or may be some one has an extra from a parts boat. I have a mast step finger to weld for sailbob2, my sister in law has a welder that welds aluminum. She is now in Fl. for the winter, if I can set up the welder, an can do the job for sailbob2. I will let you know, then I wood be happy to weild yours.
cracked tiller head
Posted: Mon Dec 21, 2009 4:47 am
by hp18carr
Thanks to all for the information, I was nervous this would be a hard fix. 20%26 thank you for the offer and if it works out, I'll take you up on it. You can e-mail me at (
glidern2954c@excite.com) Again thank you and Merry Christmas to all.
Chrysler 26 1980
Pandora
Posted: Mon Dec 21, 2009 8:08 am
by Andiron120
I had to deal with the same problem on Catch 22. I had a neighbor that does welding on aircraft weld it up for me and it has worked like a charm. Much less expensive than having one made or trying to find a new one, they are particularly proud of new ones.
