Parting out Mutineer
Posted: Sun Jan 10, 2010 12:23 pm
by seascout
Hull non-repairable. Good mast, boom, hull fittings, rudder and fitting, etc. Will ship at your expense. Mainsail shredded but have others.
Need Mutt furler spool
Posted: Sun Mar 07, 2010 10:47 pm
by Mowog
Hello Seascout:
Do you still have bits and pieces? I have a broken furler spool to replace, and also the Delrin/Nylon bushing that it rests on.
Please advise if you can help.
Thanks David
Posted: Wed Mar 10, 2010 4:32 pm
by seascout
I'll go out and take a look at it and see if it is any good.
Posted: Sat Mar 13, 2010 10:40 am
by garton_k
Do you still have the haul? I'm trying to repair a man-o-war, but it is missing the rub-rail on the stern along with the 2 corner guards. I have looked everywhere to find a replacement but have had no luck. In pictures it looks as though the mutineer has a similar rail. Does yours have this?
Kurtis
Posted: Sat Mar 13, 2010 11:49 am
by sharps4590
Will the boom vang, if it has one, fit a Bucc? I need one.
Vic
Mutineer rigging
Posted: Mon Mar 22, 2010 4:39 am
by vtrover
Hello,
I am up in Vermont a just got a Mutineer to teach my sons to sail on but the boat I got has a snapped mast, damaged boom, and rudder/tiller are missing. Do you still have these Mutineer parts available?
thanks
eric
Posted: Mon Apr 12, 2010 1:06 am
by seascout
I was able to find a home for most of the parts I had available, mast, boom, sails, rudder. All that's left is the cracked, crazed hull with some fittings. Small outboard bracket, etc. Any interest before I ditch it?
seascout
