Parting out a 10 hp Chrysler sailor
Posted: Tue Feb 09, 2010 1:41 pm
by 2nd generation
My 10 hp sailor scored one cylinder and piston last summer when my impeller failed. Since parts a hard to find I decided it was time to look for something newer. I found a lightly used 9.9 Nissan 2 stroke with electric start and controls.
I am not sure what year the Chrysler is but it is a 10 hp electric start and has the remote cables that connect to the oem cockpit controls. The boat is covered right now so I don't know if I can remove controls or not.
Let me know if anyone has an interest in any parts and we can talk.
Chrysler Sailor
Posted: Fri Feb 12, 2010 11:45 pm
by Chrysler20%26
Hi, I am on my spring count down. I should be sailing in 50 days, if all goes will I wont need parts.
Posted: Sat Feb 13, 2010 11:07 am
by DParker
I could use part of the tilt assembly. The movable bracket with pin that allows the motor to stay in a tilted position. Hope that makes sense. The pin (or maybe it is a bearing...the thing that holds the tilting bracket in place) disappeared on mine and the tilting bracket thing has since been lost. So now my motor can tilt, but there is nothing to hold it up.
Am I making any sense?
Posted: Mon Feb 15, 2010 12:36 am
by gregg
what would you like for the whole thing? Do you have the chrysler gas can?
Posted: Mon Feb 15, 2010 2:46 pm
by 2nd generation
Gregg,
Yes I have the 6 gallon plastic Chrysler gas can but I need to keep the hose for my new motor. Do you need the controls and the cables too?
Posted: Thu Feb 18, 2010 2:21 pm
by Windward
Mike --
If it's the Sailor 250 with the Magnapower III ignition module, I'd be interested in the ignition module and the coils. Mine died a couple of years ago, and while I replaced it with a Tohatsu 9.8 4 stroke, I still want to the the old Chrysler running, if only as a good excuse to purchase another boat to push with it.
PM me?
Jeff
Posted: Mon Apr 12, 2010 4:43 pm
by cyp82784
I would love to buy your old chrysler sailor my number is 262 337 3078
