Answer:
Or as I stated these issues are more about safety and common sense than legal issues. Because of this there can and are several different answers that are all very good points.
This little story was riddled with poor judgments, Well, in my opinion anyway. Most of my thoughts have been touched on already but not all. I'll list mine out and you will see that even more were mentioned than I had in mind! LOL!
1) Bob never pre-ran his boat. He could have a dead battery, bad fuel, or even wiring issues due to rodents.
2) Bob lifted the tongue with one hand? Clearly not enough tongue weight for the described boat.
3) Bob never did a check on his trailer lights.
4) Bob is missing a chain to his tow vehicle. There should be at least two and they should be crossed.
5) Bob hooked his chains to his tow vehicle bumper. The chains should be firmly attached to the tow vehicle frame not the bumper.
6) Bob and wife tossed all their gear in the back of the cockpit. Without a properly secured load they will lose items and likely get hefty tickets!
Imagine all these potential issues without even leaving his home!!
. . . and there is more!
7) Bob is in a hurry to beat crowds. You should NEVER be in a hurry when towing. You will take unnecessary risks.
8 )Bob is going freeway speeds with an unstable load. Remember the tongue weight? the trailer will cause lifting of the rear of the tow vehicle!
9) Bob is towing in overdrive! You never tow a large load in overdrive! You should always turn overdrive off when towing!
10)Bob floors it to keep up with traffic while going uphill. Can you say burned up tranny clutches, over heated tranny fluid and burned up torque converter? All this is happening very slowly! Bob may find his transmission can no longer hookup when it comes time to retrieve his beautiful boat!
11)Bob rides his brakes all the way down a hill. Bob should have slowed down and down shifted using motor compression to maintain his speed. Riding the brakes will cause them to severely overheat and cause brake fade or even possible complete brake failure.
12)Bob backs his boat down the ramp with no tied owns or even the trailer cable. Should Bob need to stop suddenly he just may unload his boat prematurely.
13)Bob does not allow any time for his brakes to cool. remember he rode the brakes down a hill? Hitting cold water with hot rotors will indeed warp the rotors!
14)Bob did not disconnect his wiring prior to dipping the trailer. Hot bulbs will blow out when dipped in cold water.
15)Bob Launched his wife dead center of the ramp between the docks with no lines to a person on shore. Should the motor not start Bob will now have issues with his wife! LOL!
Capt. Bondo, I love how you wove the possible repercussions of Bobs actions directly into the story! You clearly have towed before! LOL!
OK then, those are my intentional issues I hoped would be discovered and most were indeed discovered!! Very nice!
However, there are extra brownie points for anyone who can list the issues that I missed and were indeed listed in one fashion or another!!!
There are more than one issues beyond my list mentioned! Who's up to find them and re list them?
Pictures stolen from internet!
