Adapting OMC motor to Chrysler control
Posted: Mon May 17, 2010 6:53 am
I replaced my broken Chrysler Sailor 280 with a Johnson Sailmaster 9.9 but I'm still using the Chrysler control and cables. Here's how:
First, I found an OMC remote kit on Ebay. This was an easy coversion and comes with excellent instructions.
I took the "Chrysler" ends off the cables and made new ends for the cables using 10-32 threaded brass standoffs from McMaster Carr. All it took was cross drilling them for the clevis pins the Johnson uses and bit of hand grinding to make them the right thickness to fit in the clevis pin "yokes".
I hooked it up yesterday and everything works. Throttle is full travel, shifter works. I used a bit of Rescue Tape on the cable to make a tight fit where the Johnson holds the cable casing. The only change is that now pulling back the lever puts us in forward and pushing forward puts us in reverse.
BTW, I never liked having to reach back to the motor for the stop button, so the old Chrysler stop button now resides in the cockpit under the start button.
