Center board gasket replacement
Posted: Mon Jun 21, 2010 7:07 pm
by turfdog
The center board gasket on the Mutineer I have needs replacing and looking for suggestions as to what material to use and where I can get it.
Posted: Tue Jun 22, 2010 3:02 am
by Mario G
Can you post a picture of the old one? There are automotive seals of all kinds .
Posted: Tue Jun 22, 2010 3:50 pm
Seen some Coronado C15 types use the garage door bottom seal material. I think the factory replacement material for those boats is sailcloth over mylar.
Centerboard gasket
Posted: Wed Jun 23, 2010 8:17 am
by turfdog
There are two different types of gasket rubber on it now and it looks like garage door material but the mylar material sounds like a better idea. Any thoughts on where I can get this?
Posted: Wed Jun 23, 2010 9:00 am
by Guster
I replaced mine with this, (3" wide)
http://www.apsltd.com/c-100-SlotStrip-C ... erial.aspx
And followed Ray's instructions here,
http://www.mutineer15.org/Rey_s_Upgrades.html
Just open the .pdf CB gasket replacement.
Good luck,
Posted: Wed Jun 23, 2010 9:12 am
The thread I was looking at mentioned Ullman Sails as a source, but you probably could Google a better source that would be less costly.
If you haven't found it here's an article on replacing that gasket
http://www.mutineer15.org/files/37061448.pdf
Centerboard gasket
Posted: Thu Jun 24, 2010 1:14 pm
by turfdog
Thanks to all for the help. The link for the material is exactly what I was looking for. This forum is the best. Will have to post a picture once I am done.
Greg
