Mast Stepping C26 (1979) top heavy and will not rest on rear
Posted: Fri Sep 24, 2010 10:45 am
I have sailed for years, mostly bigger boats, went down to a Catalina 25 and then picked up a C26 this past spring (1979 model).
When I went to raise the mast via the Chrysler system this summer it was top heavy and would not stay in the pivot pin while resting on the rear rail but instead wanted to flip up and out. Is this normal?
On my Catalina there was no problem with the mast balance and it was definitely bottom heavy enough to make it easy to put into the pivot brackets (did build a mast raising A Frame for the Catalina which worked out great for keeping it from moving side to side as it was raised).
Since I wasn't sure about the balance issue and not wanting to let the mast get away from me while rainsing it (which it did when I took it down to trailer it home after I bought it) I just paid the yard to raise it.
My mast looks original and has the pivot bracket, per the book diagrams, at the bottom but the top heavy nature of it has me worried about trying to take it down again via the Chrysler system and having it get away from me AGAIN.
Any imput as to mast balance, mast length (so I can measure it and see if it is really original), and how to keep it in the pin in the bottom of the mast as it is lowered and raised would be greatly appreciated!!
btw ... I love how the C26 sails. If I can get the mast raising/lowering thing worked out I will be able to do with it what I bought it for, week long cruises at more distant locations.
Stephen
Lake Erie sailor
Stephen
Lake Erie sailor
