C-22 Tiller 2 rudder post H bracket
Posted: Mon Feb 21, 2011 10:17 pm
by Paul
I'm looking for the H shaped bracket that bolts to the aft end of the tiller and slips over the fitting at the top of the rudder post. This piece allows the tiller to be raised and lowered. I'd include a picture, but I don't have the part I need! :lol:
Posted: Tue Feb 22, 2011 5:57 pm
by Windward
If one doesn't turn up, you could have one fabbed up from aluminum or stainless pretty easily. Should be a pretty simple build.
Posted: Tue Feb 22, 2011 10:37 pm
by Paul
Thanks, Jeff. It appears from the pictures that this was a cast piece. I could fab one out of stainless barstock but would like to find an OEM if it is out there.
Posted: Wed Feb 23, 2011 5:42 am
Hi Paul,
I do not have another one of these, only the one on the boat. Is this the part your talking about?
(Double Click to Enlarge Photo)
Do you need measurements off this Aluminum part? If this is the right part, it seems to me you could make it with 2 flat bars of Stainless and a Small rectangular block of Stainless bolted in the center of the "H" to hold the 2 flat bar stainless plates wide enough for the tiller to fit in between. That center block could maybe be a hard wood too or another less expensive material like say nylon or PVC.
Posted: Wed Feb 23, 2011 8:56 pm
by back2class
If this is the part you need I can sell this one to you.
