New Trick learned
Posted: Tue Apr 12, 2011 9:45 pm
I've been reading The Complete Trailer Sailor and found a nifty paragraph for going after those above deck leaks. As you know these leaks can come from any bolt, screw, seam, etc that goes through the upper part of the hull. In addition, a leak may travel some distance before finding another hole where it can enter the cabin area. These are hard to track down.
The author makes a tripple thick cardboard piece to replace one of his passageway boards. He then seals up the inner part of the boat and places the boards and cardboard piece in place, duct taping the joints to seal these as well. After sliding the hatch shut and sealing it a leaf blower is inserted into a hole in the cardboard and turned on. While it pressurizes the inside of the hull he uses soapy water on the deck, looking for soap bubbles to form - and that's where the leak is.
Sounds like a simple soap solution to me!
