Mast Base Fix ?
Posted: Wed Jun 01, 2011 2:58 pm
by BC
In stepping the mast for the first time --1981 TMI C22 new to me -- the insert into the bottom of the mast that captures the "hook" was very loose and able to move around quite a bit. Looking at it after getting it positioned, the base had been screwed in 3 places with # 12 screws. It seems thou" the rivets had long since lost their grip.
While it's up and held in place by the shrouds I'm not going to fool with it but when I next step it I'll need a solution. Is their an upgrade anyone could suggest for when that time comes?
Thanks BC
Posted: Wed Jun 01, 2011 4:20 pm
by mcrandall
Look for the thread titled "Mast Step Crack." And especially check out John Stahl's photos of his solution:
http://s1082.photobucket.com/albums/j37 ... %20repair/
Lots of really good work done in this area over the winter months!
Welcome, by the way!
Posted: Mon Jun 06, 2011 2:44 pm
by John Stahl
I think he is describing the insert in to the mast not the mast step. my mast plate was screwed on too. one screw was loose so i put a dab lock tight thread restorer on it and held with no problems. It could be a bear to get off the nest time.
step
Posted: Mon Jun 06, 2011 3:06 pm
by BC
yes John you'r right it is the mast insert that's mangled.
Thanks mcrandall I may be able to use the hinge as is in your suggested link Thanks to both
If any others have a suggestion I'm all ears / eyes thanks BC
Posted: Mon Jun 06, 2011 4:07 pm
by mcrandall
Ah yes! I stand corrected!
Just pulled the top of my mast off. Every screw came loose, too easy, save one. Yep, you know it, I'm drilling and retapping.
