Hardware failure and shredded sail on my Manowar
Posted: Thu Jun 02, 2011 9:41 am
by manopeace
Tried sailing my Manowar with my son last Sun. The winds at the local reservoir were strong and gusty. Made it across the lake once but on the way back the snap connecting the boom to the back grommet of the sail broke and we became helpless in the water. The violent luffing of the sail shredded the back edge. A kind fisherman towed us in. Fortunately there is a local place to get the sail repaired. My sail has always been kind of jury rigged in its attachments to the boom. I wonder if anyone has any rec's for a good way to attach the sail to the boom and what kind of hardware to use to avoid the above scenario in the future.
Posted: Fri Jun 03, 2011 5:39 am
Well,
I'm not familiar with the setup on a man-o-war but it sounds like a loose footed sail.
If the sail was set up loose footed but the sail was designed with a bolt rope or slugs on the foot, that may be the issue. The grommet was not strong enought to hold the sail. IS there a track or slot in the boom?
Posted: Fri Jun 03, 2011 7:43 am
by manopeace
Yes, it is a loose footed sail. Not sure what is the best way to attach the sail with this type of sail.
Posted: Fri Jun 03, 2011 7:49 am
Do you have some detailed pictures of the end of the boom and the set up where it failed?
What exactly broke?
I picture the grommit pulling out of the clew of the sail?
Or the rope that ties to the grommet in the sail broke?
Or maybe the block on the end of the boom failed?
Pictures would likely get some better answers for ya!
Or of another Man-o-War sailor can take photos of the set up for us to see we can help out better!
Posted: Fri Jun 03, 2011 8:30 am
by manopeace
I will try to get pictures posted. Thanks
