outboard question
Posted: Sun Jul 03, 2011 11:13 am
by teosails
I don't have a Chrysler sailboat, I have a Chrysler 25 Sailor outboard. What I am interested in is... is there a way to rig the throttle and gear shift to work from inside the cockpit? I have a Coronado 25' sailboat that has a dedicated compartment for the engine, but only a small access hole to reach the controls. Very difficult to maintain control and adjust engine speed or direction.
Any ideas would be helpful. Thanx
Posted: Sun Jul 03, 2011 4:57 pm
by excavman
I rigged up a remote throttle for my Honda by using an $8 lawn mower throttle cable and mounting it on the tiller. I had to fabricate the pieces to tie it into the throttle linkage but that was no problem, just took a little head scratching.
The gear shift is pictured in the post two up from here. That may not work for your application but might give you an idea.
Larry
Posted: Sun Jul 03, 2011 6:21 pm
Now that is a throttle I could live with. Do you have more photos of this Larry? Like the connection to the motor and how you ran the control cable.
It's out of the way, small, I like it!
Re: outboard question
Posted: Mon Jul 04, 2011 4:21 am
teosails wrote:I don't have a Chrysler sailboat, I have a Chrysler 25 Sailor outboard. What I am interested in is... is there a way to rig the throttle and gear shift to work from inside the cockpit? I have a Coronado 25' sailboat that has a dedicated compartment for the engine, but only a small access hole to reach the controls. Very difficult to maintain control and adjust engine speed or direction.
I think these came setup to accept remote controls - Simply the best source for Chrysler outboard info is Franz Buddenberg at
www.franzmarine.com !
He is the guru.
Posted: Mon Jul 04, 2011 1:13 pm
by excavman
Here you go Alan, a little 'in depth' view of the lawn mower throttle setup.
I ran the cable over the top of the transom but it could easily be run through the laz and out a drain hole. This hookup is on a four-stroke honda, it may not be workable on yours but it'll give you some ideas.
There is a gromet right next to where the twist grip throttle cable goes in. I think that's where the factory made remote would go. I just poked a hole in the gromet to run the line in.
I used the anchor for the original control and just cut in a groove with my Dremel for the wire to drop into.
The linkage already had a second connection point for the factory cable so I just made a end piece out of brass to hook up the wire to the link.
Then, just to make sure things worked as planned I added an extra throttle spring to make sure she came back to idle when needed.
Don't you just love it when a plan comes together?
Larry
