Portlight cut out resizing in terms of reduction
Posted: Wed Jul 19, 2006 5:44 am
Hello everyone -
I have a C22 with the original portlights. They leak, look terrible, etc.
I'm looking at some new portlights that open, but I'm finding that the openings that are needed for new portlights don't work. It isn't a matter of simply needing to cut a larger opening - it is a matter of needing to reduce the length of the present openings.
The way I look at it, I can install a new portlight and have it fit in correctly on the top, bottom and one end. The other end, however, would have a gap of a few inches that would need to be filled in/rebuilt.
Bascially, I would need to restore the outer surface of the cabin, have a layer or two of fiberglass mat, some sort of plywood or deck material, another layer or two of fiberglass mat and then I'd need to restore the inner cabin appearance.
I'm just wondering if anyone might be aware of the procedures that should be followed to make a portlight opening smaller - if it can be done that is.
Thanks for any advice you are able to offer.
Mike
Madison WI
Mike
Madison WI
