Please check your keel cable
Posted: Sun Oct 02, 2011 12:24 pm
by N41EF
It didn't look bad at first glance. I noticed that someone had bent the pin that screws in, but I could crank the keel up off the trailer, and lower it to the wood on the trailer.
Since I had to take the winch cable loose to clean the mud dobbers out od it, I thought I'd check the cable.
So the shackle had actually worn about half in two:
And the cable had erroded about in half as well, scary part was there was a threaded shackle that was prob 90% Gone.
Thanks to those who have gone before me, I'll be at Tractor suply Monday to buy some stainless cable.
Posted: Sun Oct 02, 2011 1:52 pm
by turbo1168
GOOD CATCH! Much better to see that much rust and corrosion while sitting on the trailer, than in the water after the keel fell and damaged the pin and brackets. Could have been ugly. Plain steel should not have been used in that application. When you get the cable, make sure to use wire that is designed for the constant winding. 1 X 19 cable shouldn't be used, it will fatigue from the constant rolling up around the winch drum. 7 X 19 is designed for that action. Some people have also used the newer, high strength / low stretch rope.
Posted: Mon Oct 10, 2011 9:45 am
by N41EF
Just a little homework for those that follow. According to the Chrysler build drawings, the cable is 91 inches long made of 3/16 Stainless Steel. Here are the options I found:
1. Home Depot sells the cabe and has "kit" for about $8 that includes a thimble and two stainless cable clamps. They will cut the cable to any length you want.
2. Tractor Supply sells cable and individual pieces for slightly higher price.
3. West Marine has a crimper mounted and will make the cable for you as long as you are buying the parts from them. If you need an excuse to go to Wests, this is the better option. About the same price as TSC. You can mail order the cable, thimble, and clamps if you are remote. I'm not allowed to go to West anymore by myself with a credit card.
I got the parts and built one from TSC, then found the HD kit, so I made a back up cable using the HD kit and a piece of galvanized cable. For now it's ballast up front.
For those without a lot of marine shops around, check TSC of Home Depot.
Posted: Mon Oct 10, 2011 9:55 am
by turbo1168
Fortunately for me, Seco is right down the street, but if you need any rigging done try them, they do ship.
http://www.secosouth.com/mm5/merchant.m ... g_hardware
