keel pin
Posted: Sat Oct 15, 2011 1:44 pm
by blu by you
done with north jersey im finally back in florida and close to my boat. wifey wont let me near the boat until i unpack everything (should take less then a week) i snuck over to see the boat and took a quick look for the keel pin couldnt find it. the cable looks to be in ood shape how do i check the keel pin....it seems t be up inside the hull
Posted: Sun Oct 16, 2011 12:18 pm
You are correct sir, it's up inside the hull and hard to see.
If you on shore, get a mirror and and flashlight.
Crawl under the boat to the keel.
Put mirror at a 45 degree angle to the bottom of the hull, up against the keel and shine the light in the mirror.
This should light up the keel pocket and give you a view up inside that pocket.
The keel pin is approximately 12 to 18 inches back from the front of the keel pocket and about 8 inches from the bottom of the hull.
Inside the boat look in the forward seat and that big black rubber disk on the port side of the of the cabin floor.
Posted: Sun Oct 16, 2011 4:18 pm
by blu by you
thanks allan
Posted: Sun Oct 16, 2011 4:30 pm
Any time, my friend.
