New power Panel For Lady Jo
Posted: Thu Oct 27, 2011 5:55 am
After searching and studying all the posts for various power panel ideas I finally settled on one for my new Lady Jo. Mostly copied Mariners idea! Thank you sir for that!
So, picture looking in the companion way. Look down and to the port or left. This is mounted just aft of the table and into the fiberglass. See the white in the top left corner of the photo? That is the funny shaped shelf. The wood above is the trim on the shelf above the table!
The main power switch was bought at a garage sale brand new for 5 bucks! Yeah baby! Also got some nice anchor chain!
After searching the internet for a nice looking breaker panel, I could not get myself to spend all the extra money for a panel with LEDs. However, being a gadget guy I had to have the LEDs because the look cool! LOL!
What I did was buy the panel with no LEDs at a substantial savings. Then simply went to radio shack and bought 12v LEDs! I drilled and mounted them myself. The bottom LED comes on when the main power switch to the left is flipped on. If the battery is hooked up backwards, the LED will be yellow. IF properly hooked up, the LED is red. I mounted this one first centering it on the panel. I wish I would have mounted it last and aligned it with the other LEDs! LOL!
All the other LEDs are off when their respective switch is off and on when the switch is on.
So, again, thanks Mariner for your ideas on where to mount the panel!
Also, for the curious, I mounted the battery in a battery box in the port lazerette as far forward as it will go and as far towards the centerline of the boat as I could get it. I through bolted the battery box to the floor of the lazerette. If you do the same, use extreme caution. there is plenty of room to drill towards the center of the boat but as you move outward the hull comes up to the bottom of the lazerette. No reason to install a fountain in my boat! LOL!
Hope you like it! I do!
Stereo, VHF, and LED lighting coming soon . . . . . . .
