electric
Posted: Sat Nov 05, 2011 3:04 pm
by blu by you
i found the wires going to my mast light to be in poor condition , has anyone run new wire through the mast and how hard was it. thanks
Posted: Sat Nov 05, 2011 3:23 pm
by Bhacurly
It's a good Winter projecr.
I know Alan did it recently an there is a good post on it here somewhere.... Here it is.. good info:
http://www.chryslersailors.com/discussi ... sc&start=0
Posted: Sat Nov 05, 2011 4:19 pm
by lecker68
Make your Harness outside the mast and then use a wire snake longer than your mast you may be able to pull a chaser line in with your old wiring and pull the new wiring in with it.
Posted: Sat Nov 05, 2011 7:10 pm
by blu by you
again the site comes through many thanks
Posted: Mon Nov 07, 2011 8:50 am
by johnjax292
I have also seen a trick using a strip of cloth tied to your wire harness and a vacum at one end of the mast. The cloth is pulled through by the vacum...it worked better than expected.
Posted: Mon Nov 07, 2011 12:15 pm
by thepartydog
When I'm running network cables thru conduit, I use a walmart bag, pull string and vacuum. Works great.
