Mounting idea for in window solar panel
Posted: Fri May 18, 2012 9:03 am
by Capt. Bondo
Couple folks use these little solar panels in the side window, and let them just rest in the curtain.
I wanted to make sure my panel was as close as possible to the window to catch as much sun light as possible.
So in Bondo style a couple bungies and some pipe insulation foam does the job. pull the curtain back over it and you don't eaven know it's there.
Pipe insulation foam is also great for sealing up the top hatch board to the sliding hatch to keep the wasps out, and any edge that is rough like the tops of the bulkheads in the aft storage.
Posted: Mon May 21, 2012 5:08 pm
by skyking
I was just considering using small bungees as well. I just got my solar panel last week and its already falling out of the window.
Thanks for the tip...The pipe insulation appears to be the ticlet..
Posted: Mon May 21, 2012 7:30 pm
Nice idea!
I like it!
Posted: Wed Jun 13, 2012 2:22 am
by 38 special
What a great ideal, I just bought a 1.5 watt panel from Harbour freight and was look for a place to mount it....Thanks
