Boom Topping Lift
Posted: Sun May 20, 2012 4:10 pm
by N41EF
So, reading "Sailing Fundamentals" and it talks about rigging the boat and using a boom topping lift. Looks to be a line from the top of the mast that holds the rear end of the boom up while you rig the main sail onto to boom, or when you have the sail on the boom.
It shows a second not prefered method of using a short line attached to the back stay. My C22 boom has a snap hool on the back that I assumed you clipped to the back stay for this purpose.
What do you folks do?
Posted: Sun May 20, 2012 5:37 pm
by Bhacurly
I have both...
The topping lift also runs through a pulley at the mast head and base to a clam cleat in the cockpit so I can raise the boom up high at anchor. I use the one on the back stay in the slip, or overnighters, to keep it from swingin sideways.
Posted: Sun May 20, 2012 6:03 pm
EE has a topping lift from mast head to boom, and I pull the mainsheet tight to keep it from swinging at rest...the Cal21 had a clip from boom to backstay, forgot to unclip it once when setting sail which prevented me from letting the main out in some nice wind,,got a bit exciting..for that reason I prefer the masthead lift...just my two cents worth
Posted: Sun May 20, 2012 7:31 pm
by Capt. Bondo
I have just the short line from my back stay. Easy to use once you get used to remembering you have it, the boom falling into the cock-pit will remind you :shock:
If your mast stays rigged for the season a topping lift is the way to go.
Posted: Sun May 20, 2012 8:36 pm
by Chrysler20%26
I do as EE, I use a 3/8 line tied at mast head, a end of boom. That way the boom can help in a man overboard. You can put a block an tackle on the end of the boom. If you ever have to pull something out of the water.
Posted: Mon May 21, 2012 11:51 am
by tgentry
One nice thing about a masthead topping lift vs. clipping it to a backstay:
At the dock I tie the boom to the side of the boat away from the dock. It keeps it out of the way and snugging up the main sheet keeps it from swaying.
I use the tail of main halyard, run to the cockpit and through rope clutch. It goes from rope to just in front of the nearest lifeline stanchion, under the lifeline and ties to the boom. Any short length of line tied to the stanchcion would work the same.
I also like to fly flags from my topping lift.
Posted: Tue Jun 19, 2012 8:33 am
by Padiunka
I use the main halyard on my Buccaneer as a topping lift when at anchor or at the beach to keep the boom above head height.
Who on earth anchors a Buccaneer? This guy! Gotta stop to mix drinks sometime!
