Question for C-26 owners
Posted: Fri Jun 22, 2012 10:15 am
by SN691
I have a question for C-26 owners. What kind for fuel tank do you have , is it the original or has it been replaced with a newer one? If it has been replace do you know the brand name of it? How long, wide and high is the fuel tank? I have the original 6 gallon metal fuel tank, and I need to replace it with a new one
Posted: Fri Jun 22, 2012 12:43 pm
Attwood 6 gal plastic from happyfacerollbackstore..fits in there but you have to be a bit creative to tuck it in the hatch..
Posted: Fri Jun 22, 2012 2:10 pm
by lecker68
same as EE Atwood 6 gallon fits under stern laz. to Starboard.
Posted: Fri Jun 22, 2012 10:58 pm
by Chrysler20%26
An put the tank in, be for you fill it with gas.
Posted: Sat Jun 23, 2012 3:41 am
Chrysler20%26 wrote:An put the tank in, be for you fill it with gas.
True ! I did put in once with fuel in it....the first time..
Posted: Sat Jun 23, 2012 9:03 am
by SN691
Posted: Sat Jun 23, 2012 2:07 pm
EE came with that type and there was no bracket . Rubber strap. Might do a dry run on putting it in empty before loaded. You sort have to put one corner in and down then work the rest in. Not too hard but there's a trick to it!!
Posted: Sat Jun 23, 2012 3:43 pm
by lecker68
Mine did not have a tank or and engine when I got it and you do not want to put it in full.
Posted: Sun Jun 24, 2012 12:55 am
by Chrysler20%26
In your case, your marina dose not allow you to take gas to your boat. Why don't you get two 3 gal. tanks.
Posted: Wed Jun 27, 2012 8:31 am
by tgentry
I still have the original Chrysler tank so, I'm no help there. The boat came with nothing holding the tank in place. I installed a hold down kit from (I think) that same store mentioned earlier.
Posted: Sat Jun 30, 2012 2:01 pm
EmergencyExit wrote:Attwood 6 gal plastic from happyfacerollbackstore..fits in there but you have to be a bit creative to tuck it in the hatch..
Was there today and the shape of the tank has changed since last time. looks shorter and taller now, you might want to double check the lazarette height.. And it was almost $50 as opposed to $35 online.
Looks like the Moeller 6 gal is more the same shape as my old Attwood 6 gal.
Posted: Tue Jul 03, 2012 10:34 am
by SN691
Posted: Tue Jul 03, 2012 11:42 pm
by Chrysler20%26
Thank you for the info an photo. What was wrong with the old tank, I have one just like it.
Posted: Wed Jul 04, 2012 12:46 pm
by SN691
Posted: Thu Jul 05, 2012 5:43 am
by Chrysler20%26
Thanks Bob, your new tank should fix the condensation problem.
Posted: Mon Jul 09, 2012 10:09 am
by NYCSAILOR
How many hours of operation do you get with the 6 gallon?
Also, what fuel grade do you use ? regular or plus ( I have a four stroke...)
I was going with a 3 gallon since I thought I had enough weight on the stern, the Four stroke, the battery , the gas, the passengers.. etc... I saw in the forum some guy rigged a flexible gas tank in the v berth with a electric pump... but i worried that was way too dangerous for gasoline...
august is coming. not much wind and was thinking about my motoring range... also, looks like that new attwood tank does not have a vent ! and I also worry.. I have some bolts coming through the transom that might chafe through the plastic...
Posted: Mon Jul 09, 2012 1:46 pm
by clair hofmann
When I get to the point of doing a fuel system I will mount a 12 gallon tank under the cockpit. I have used this system on one of my Ventures for 10 years and it works well. I use a combination fill, vent cap mounted on the stb. combing. No fumes in the cockpit or cabin and one fill lasts the summer.
You shouldn't be filling portable tanks on board.
Clair
Posted: Thu Jul 12, 2012 11:43 am
by SN691
Posted: Thu Jul 12, 2012 12:27 pm
I had a problem getting EE to start when I replaced mine with an Attwood. Turned out the existing quick connect at the tank end of the hose wasn't the right fit for the fitting on the tank. I replaced it with a screw in fitting and it was fine after that..I do have to take the fuel line with me to fill up off board, but its not that big a deal..
Gas Can Replacement
Posted: Tue Jul 31, 2012 6:44 pm
by bearley
I bought a Moeller "Scepter" 6.6 Gal. (US) tank off from Amazon just three weeks ago for $41.00 delivered. This slightly larger tank fits the stbd. lazaret perfectly. But now kit seems that model isn't available, and the new model is only 6.0 gal and it's a lot more money. It looks to be the same basic size, and it does have a built-in out valve which mine doesn't have.
