Mast step repair c26
sailxnite
Post by sailxnite »
I am attempting to repair the mast step on my c26- i am including a link to some photos https://picasaweb.google.com/sailxnite/ ... directlink as well as a diagram- https://docs.google.com/drawings/d/1Cym ... tTfCQ/edit
any advice you could offer on the best way to repair would be appreciated.
1977 Chrysler 26
Welcome aboard! Glad to have ya here!
Someone should pop up with some help for you soon!
Tell us more about yourself and your boat!
Been there, done that one, although not to the extent you had to as my underlying wood was ok. I had the step plate rip out while stepping the mast
If it were me I'd rebuild it pretty much the same way as original. But I'd take some steps to insure it didn't happen again such as adding some weepholes at the base to let moisture out. Or maybe be sure to coat the replacement block in resin and glass..
sailxnite
Post by sailxnite »
EmergencyExit wrote:Been there, done that one, although not to the extent you had to as my underlying wood was ok. I had the step plate rip out while stepping the mast
Thanks for the info, any idea what type of wood to use for the replacement block?
1977 Chrysler 26
hp18carr
Post by hp18carr »
Sailxnite
Welcome to the forum, I do like your C26 mast step diagram, I'm not at the point in my project to work mine just yet but you can see I also have a crack to deal with and what checking I've done up to this point has me believing that the damage is mostly superficial. Removing the screws and step showed no wood damage as of yet... hopefully my prognosis will hold true when I get around to this part. Again welcome and the more photos the better. 8)
Chrysler 26' 1980
sailxnite
Post by sailxnite »
Terrence,
keep an eye on that crack, that is how mine started, i think once water penetrated the gelcoat, it froze and made the crack bigger, until water started getting into the core material. keep it sealed really good. There was no barrier from the mast step down through the cabin top core material, so I think i may have some deck repair as well.
Pat (sailxnite)
1977 Chrysler 26
Looks like the underlying wood in yours was same as mine
http://pwp.att.net/p/s/community.dll?ep ... thumbs&ck=
but my damage was limited to the glass layer. I'd sure go with a hardwood, as dense and rot resistant as possible
hp18carr
Post by hp18carr »
Pat
Thanks for the advice, I do have the step covered better than what the photo implies and with luck we don't get many hard freezes in Wilmington N.C. Even so to play it safe I'll move it high up on my to do list.
Chrysler 26' 1980
tgentry
Post by tgentry »
Personally, I wouldn't over-think it. The original setup lasted 30 years, so redoing it the same way should be fine.
sailxnite
Post by sailxnite »
1977 Chrysler 26
Gus
Re: Mast step repair c26
Post by Gus »
sailxnite
Post by sailxnite »
Yup, I am a "Belt and Suspenders" kinda guy :)
1977 Chrysler 26
tgentry
Post by tgentry »
That looks bomb proof! Be careful you don't chip or crack the hatch when you slide it open, it looks like it could contact the new mast pedestal.
Steven&kay2013
Post by Steven&kay2013 »
Looking for parts that are similar to this mast step for a 1975 Chrysler 22. Any pics links or info appreciated
Steven&kay2013 wrote:Looking for parts that are similar to this mast step for a 1975 Chrysler 22. Any pics links or info appreciated
Welcome aboard ! If you are in need of the mast step hook, I'd encourage you to look into a mast hinge plate. Much better solution than that hook was..
darmah
Lost hook base for mast
Post by darmah »
Where did you obtain the mast base hinge and how did it fit into Chrysler mast?
Tb or not tb
There are several good threads on the subject, one is at
viewtopic.php?t=3375&highlight=mast+hinge
if you click on Search, then enter "mast hinge" and choose 'Search for all terms' several should show up as well..
