C22 Spreader Configuration
Posted: Tue May 06, 2003 10:15 am
I've got some questions about the spreader configuration on a C22.
Here's what's up there now:
A length ( i really should have measured) of solid round aluminum about 1" in diamter (OK, OK, I'll measure everythign this weekend) for each spreader. Both spreaders appear to be tapped and through mounted with one peice of threadstock, thourgh the mast. Not really sure if there is a compression spacer in there or not. On the outboard end of each spreader a groove has been cut with a screw and plate holding each shroud. My biggest concerns are: a) the spreaders are bound on the thread stock and and cannot be turned to adjust b) the grooves in the spreaders are not aligned so that both shrouds can run exactly vertical through the spreaders.
When I rigged and raised this last weekend, that bothered me a little, and is really under my skin now. I would like to get that few degrees of mis-alignment out of there, because I am smart enough to know it has an effect on strength. Unfortunately I am not smart enough to figure out how much.
Unless someone can tell me what the config is supposed to be, I am find the best match of the mast profile from either DR Marine, Rig Rite or Dwyer Mast and replace the current setup with a bracket and extrusion.
Sometimes, it really would be nice to just be able to order a simple part, and not spend all this time trying to figure out what is available today to match what was done yesterday. Sometimes, it is fun.
