Mast Stepping Tip
Posted: Sun Nov 18, 2012 5:43 pm
Stepped the mast at Pass Harbor today, and can add another thing to watch out for.
Had the mast all the way up, but needed a bit more to get the forestay to the tang hole..but when I pulled hard on the sheet the boom/pin pulled free from the mast. Luckily the redhead had a firm grip on the forestay or the mast might well have gone crashing down.
There's a point at which you are no longer pulling 'down' on the boom with the tackle. You are pulling more 'forward' on the boom because the end of it is a bit behind the forestay attach point.
By the way, the reason we couldn't get the forestay to the attach point was because I had the rear baby shroud too tight. Once that was loosened the mast moved forward enough to easily attach the forestay. Should have checked that instead of trying to really crank the last few inches from the tackle !!
Oh well, all worked out !
