Tried to update my avatar image today, and discovered that the size has been reduced....this is really cramping my style... any tips on reducing file size?
update: I found many ways to reduce the size, so now I have a problem, my image is 28KB and the size is 200x240 pixels, and I cannot upload it......
Avatar image size
Avatar image size
1976 - C22
"AnneMarie"
"AnneMarie"
Far as I know the maximum size hasn't changed, 200x240 should work fine as far as physical size, but there is a second component of image file size and thats about 101kb, so you may also need to save in another format, or reduce pixel quality a bit..
EDIT - duh, I see your file is already only 88kb so it should upload, and 192x250 according to the properties, which is close to EE's avatar specs
my personal (at present) fav image editing software is GIMP..a freebie.
http://www.chryslersailors.com/discussi ... c.php?t=88
Hope that helps !
Hope that helps !
