Chrysler 26 launching
Posted: Sun Jul 07, 2013 7:44 am
by KenO
Posted this in the trailering area and got no replies. When I launched my swing keel 26 the other day the truck was farther in the water than I wishes as there is no extended tongue on the trailer. Has anyone ever used the system of detaching from the towing vehicle and placing a large wheel on the tongue and using a towing strap to put the trailer in the water while the vehicle stays dry. saw a Santana 20 do this successfully but is a much lighter boat.
So far we are enjoying our new 26
Posted: Sun Jul 07, 2013 3:20 pm
by lecker68
I was thinking of the same thing but 2 wheels oriented in a straight position.
Posted: Mon Jul 08, 2013 4:33 am
I've always wondered about the haulout tho..if you needed the straps to get trailer in water far enough, seems to reason you'd need them again to haulout..guess they're plenty strong to pull the boat back out with ?
Posted: Mon Jul 08, 2013 9:07 am
I've never done this however I have a friend who has used this method extensively. Same issue. No tongue extension and did not want to dip the PU.
I understand if done properly it is highly effective.
Welcome to the forum and sorry we missed your first post!!
launching
Posted: Mon Jul 08, 2013 11:59 am
by aerojet777
i ran into this problem and what i found was my keel was slightly down just a few inches so the boat wouldnt come out. once i tighted the cable it came out with only about 5" of water on the back wheels of my truck. the angle of the ramp will cause the boat to roll out even if its not totally floating.
this was with an ez loader trailer, if its carpet it may need to be deeper.
Posted: Mon Jul 08, 2013 1:37 pm
by KenO
Since I posted talked to a full keeled Catalina 25 skipper. He uses a single nonturning wheel on a fork attached to a pivoting anchor on the tongue. Uses a 8000# tow strap to lower and retrieve the trailer/boat. Need to stop on the ramp, block the trailer tires and attach the strap and tire. Pull forward un block and allow the trailer to descend the ramp. He says is very safe.
On another note, my boat came with a 150 jib. Too big. Best place to get a new 130?
Ken
Posted: Wed Jul 10, 2013 9:20 am
by Capt. Bondo
Depending on the water level on the river;
On low water level I only need to back in until the back tires touch the water 8)
On high water I need to back down until the back bumper is almost submerged to float the boat off/on. :shock:
The marina ramp get steeper farther down.
Posted: Thu Jul 11, 2013 12:35 am
by Chrysler20%26
Posted: Thu Jul 11, 2013 4:14 am
Chrysler20%26 wrote:My C-26 has a EZ Loader Trailer ( I think most C-26 boats came with this type of trailer ) You can use the winch to pull the boat out of the water. By adding a block near the end of the trailer, an running the winch cable thru it an back to bow eye You can pull the boat off the trailer. Vary Little Water Needed
Or the EE method - back trailer up at a good clip and slam on the brakes, lol..best have it tied to something solid before you do that ! Comes off and hits water at a fair clip. :shock:
