What to look for when buying a C26?
Posted: Fri Jul 19, 2013 7:02 pm
by CraigWik
I'm looking at a C26 Sunday that I'm thinking about buying. Does anyone have any specific suggestions on what to look for or look out for? It's a 1977 model. Sorry if this question has already been posted before. I don't see a way to search for text in old postings.
Craig
Posted: Fri Jul 19, 2013 10:07 pm
Welcome aboard!
One of the C26 owners will for sure chime in here for you!
In the mean time, if you are reading this, look up to the top center of this page. You'll find the search function there!
Again, welcome and keep us posted on your possible purchase!
Posted: Sat Jul 20, 2013 4:46 am
Welcome aboard ! Hey where's the boat located ?
They have a few recurring issues, but none other than maybe hull blisters are majorly expensive repairs. Mostly they are areas that were originally underbuilt and need correction or beefing up after all these years. You can click on the link to EE's site below my post and see most of these items or locations..
Expect a soft spot at the bottom of the companionway steps, not a big fix at all. Thats plywood over the small bilge area and tends to get wet if the bilge was left full a lot
The 77's didn't have the anchor locker up front so the usual water damage to the bulkhead up there doesn't apply (its a 79 model thing for sure)
Original motor mount may have cracks in the corners from stress and if they are good size expect water to have seeped in and damaged the wood inside the mount walls.
Check the mast step area on the cabin deck for spider cracks. Big ones would indicate the the mast support that runs from under that to the keel is not solid, that's an under built support anyway.
Look for hull blisters if out of the water. Also if out of water look at the rudder cheek plates, they tend to have stress cracks at the leading edge.
In the stern berth area, run your hand up in the area where the hull joins the deck and feel for wet areas there, that would indicate hull to deck joint leaking. Do the same in the vberth.
Its hard to see or tell with the table in the way, but sometimes the wood where the winch stand base attaches to the keel trunk gets punky. Goes along the with area at bottom of steps having been wet.
Overall these are a great solid boat, just very old. Sometimes you find them perfectly well maintained, sometimes not.. ok after two I haven't found one that way yet..but don't let a bit of work scare you from a good deal..
Posted: Sun Jul 21, 2013 7:20 pm
by CraigWik
Thanks for the advice. I bought the C26 this afternoon, and it's sitting in my driveway in Bloomington, MN, now. Wish I had a couple more days left in the weekend to get it into the water. Seems to be in very nice shape given the age. The previous owners took good care of it. I've been up on Lake Superior on a friend's C22 several times (Apostle Islands, Isle Royale), and we're looking forward to taking the C26 up there in September. So I've got a couple months to learn how to rig and sail this one on smaller waters closer to home.
Posted: Mon Jul 22, 2013 1:07 am
Very cool ! And welcome again !
Posted: Mon Jul 22, 2013 4:24 am
Congrats!
Posted: Mon Jul 22, 2013 9:13 am
by Capt. Bondo
Welcome Aboard CraigWik
Great to have another upper midwest Chrysler on board!
Posted: Mon Jul 22, 2013 9:49 am
by lecker68
Welcome aboard mate hope you enjoy your C 26 as much as I do mine!!!
Posted: Mon Jul 22, 2013 5:43 pm
by adamh
Congrats on the new boat. I saw that one one on craigslist and if I didn't already own one, I would have been all over it. Looks like you have a real nice and well equippd boat. We are planning an August trip up to the Apostles with our C-26 as well. Good luck and have fun.
