My HDPE Rudder...
Posted: Tue Aug 06, 2013 9:36 am
When we got the boat the rudder was in pretty bad shape. It was not secured properly when towing so it rubbed the asphalt for a while and the particle board was starting to split at the top so I just didn't want to mess with the fiberglass repairs.
So I used the original rubber as a template and sketched the outline onto a 3/4" thick piece of high density polyethylene that i had laying around the shop. The frame that secures the rudder to the tiller post has an inside opening of 1 1/2" so I cut some 3/8" PVC sheet to match the metal and keep the 3/4" HDPE rudder centered.
I know this isn't the best design fluid dynamics wise, but it will do for now. I did not have the $500 to buy a replacement HDPE rudder so as long as this one deflects the water and I can turn I will be happy. I still need to feather the leading and trailing edges and drill out the rope holes for lowering it but I couldn't wait any longer before i showed someone my creation!
