boom pin for erecting the mast
Posted: Sat Oct 10, 2015 4:39 pm
by MichiganBill
My boat did not come with the pin for attaching the boom to the mast (to work as a gin pole). I see from the manual that it's 5/8" diameter. Can anyone tell me how long the pin should be?
Posted: Sun Oct 11, 2015 6:36 am
by MichiganBill
Okay - poking around the forum I found people referencing between 6 and 9 inches long. I'll get a longer rod and trim as needed.
Posted: Mon Oct 12, 2015 6:27 pm
by astrorad
The pin only goes in about 1 1/2 inch into the mast base and only needs to go into the boom far enough so it doesn't pop out accidentally while setting up...6 inches would be plenty I think.
Posted: Tue Oct 13, 2015 5:24 pm
by MichiganBill
I didn't want to use threaded rod, as I thought it might chew up the aluminum. I found a 5/8" galvanized grounding rod at Home Depot that I can cut a bit off.
Thanks once again Bill for your help.
Posted: Wed Oct 14, 2015 11:55 am
by Capt. Bondo
I had a friend that used a trailer roller axle that he got a Fleet Farm.
In a pinch I have used a 3/8 drive x 3" socket extension from my tool box
Posted: Thu Oct 15, 2015 1:46 pm
FYI: I made that pin from a 5/8 diameter stainless bolt that was only threaded at the end.
I used a cutting wheel to cut the head of the bolt off and used 3 inches of the un threaded shaft! Works perfect. In fact I have made several over the years.
Keep in mind that while the pin will not slip onto the mast, it can and will slip into the end of the boom! LOL! Don't ask how I know and why I just might have needed more than one! LOL!
Posted: Tue Oct 18, 2016 4:41 pm
by Snowdog2
I am using a pin that is only about 3" long. I put on a rubber O-ring that fits on it snugly so that it doesn't accidentally fall into the boom.
I wonder if the longer pin prevents it from falling out when one is raising the mast? The boom and pin separate from the mast when it is close to fully raise when it doesn't matter any more.
