Starwind 223
Here's a place for Starwind owners to discuss the various models of Starwinds, a relative of the Chrysler line of sailboats.
jbreland
Starwind 223
Postby jbreland » Tue Jul 03, 2007 4:23 am
Hi,
I'm looking at a starwind 223 and have a question about the center board pivot pin. When I looked under the floorboard I saw what looked like a 3/4" piece of galvanized pipe capped on both ends with a caps.
Is this the standard setup or has this boat been modified?
thanks
James Breland
stan leathers
swing keel problem starwind 223
Postby stan leathers » Sat Aug 22, 2009 5:46 am
Did you experience any problem with the swing keel pivot? I have a 3/4 inch brass pipe which encloses the swing keep piviot which seems to be about a half inch stainless stell rod. the rod extends way farther to the starboard than to the port side of the possible range of motion. I have 2 questions.
1. is the stainless steel rod fixed in the toip of the keel or can i center it more?
2. is the 3/4 brass pipe screwed into some sort of threaded bracket such that i can take it out and replace it? To put a pipe wrench on it will destroy it if it does not come out. I may be able to get a plummer to rethread the stub sticking out and put a 3/4 brass coupleling and plug on it to again get it water tight . The origional problem was the brass cap on the end of this pipe developed a hole because the threads were either warn away or were poorly made to start with. It did make it 23 years !!
stan
Return to “General Starwind's Discussion”
Users browsing this forum: No registered users and 0 guests
